| Battle of Detroit - Woodburn and timing woes https://slantsix.org/forum/viewtopic.php?t=49432 |
| Author: | ceej [ Sun Jul 29, 2012 4:47 pm ] |
| Post subject: | Battle of Detroit - Woodburn and timing woes |
Next weekend, Woodburn. May not make this one. I went and fiddled with the ignition curve, and the car is way off. I improved things by bumping up to 34° all in. It was a bit higher than that when I started, around 36.5-37°. I need to go back in and see if I can get it back to where it was. Had about 14° of mechanical. Got 10° now. Initial at 22.5° and 32.5° all in, the car runs slow. Need to loosen up the clamp and move the timing up again, see if it will start with 25-26° initial. Probably be fine. The whole point of the excersize was to wean it off $9/Gal 110 race gas. Installed a 160° T-Stat in it, and temperature behaves pretty well now. Still runs 200° at WOT. I'm ready to go back on the 110 and just deal with it. Added a second on the 1/4 taking that timing out. Long rod engines will take a lot of timing, but this is rediculous! CJ |
| Author: | emsvitil [ Sun Jul 29, 2012 5:34 pm ] |
Use E85........ |
| Author: | ceej [ Sun Jul 29, 2012 5:39 pm ] |
It's a 15 second car again! Three guesses what the problem was? Running with All in of ~41° Bueller? Bueller? It's the simple stuff that'll getcha! CJ |
| Author: | Dart270 [ Mon Jul 30, 2012 3:39 am ] |
Loose timing tab? Slipped damper ring? Dial back timing light dial loose? Hope to see/meet you at Woodburn. Lou |
| Author: | ceej [ Mon Jul 30, 2012 4:28 am ] |
Took you two! See you there! CJ |
