It is currently Wed Oct 07, 2026 8:41 pm
 Post subject: rod bolts
PostPosted: Sun Aug 05, 2012 4:38 pm
Would somone verify this number ARP 142-6002 connecting rod bolt 225 sl6
1971 Plymouth Duster
 Post subject: Yep...
PostPosted: Sun Aug 05, 2012 5:30 pm
142-6001 is for the forged crank rods (pre-mid/76)
142-6002 is for the cast crank motor (mid-76-1987+)
That being said I've used the 142-6001 in the cast crank rods and they worked OK, I do wonder if the reverse it true...
PostPosted: Mon Aug 06, 2012 3:47 pm
'76 cast cranks? :?:
PostPosted: Mon Aug 06, 2012 6:03 pm
'76 cast cranks?
Yes, they went into the very Late 1976 F-bodies haven't seen a '76 A-body with a stock cast crank engine... (Since the cast crank was starting to be available June 1,1976...that would mean about 1-3 months of them were available for the F-body during the 1976 model year production run)
