It is currently Fri Nov 13, 2026 8:22 am
PostPosted: Mon Aug 06, 2012 10:03 pm
Hello, Pretty much what the Subject says.
I am looking for the Timken part Numbers for the Front and Rear Pinion Bearings and Associated races/cups, whatever terminology you might use.
I already have a set of carrier/spool bearings so I dont need a whole kit for this project... just the Pinion Bearings.
Any info, or part numbers would be appreciated.
PostPosted: Tue Aug 07, 2012 9:00 am
Greg, Look up doctordiff web page He has everything for Mopar diff's including Timken bearing part #'s When you find out what spool you are going to use let us know as I have a set of 4.30's that I wasnt to spool(30 spline)
PostPosted: Tue Aug 07, 2012 9:06 am
Never mind His web page isn't working
PostPosted: Tue Aug 07, 2012 9:26 am
From Timken web site. Inner M804049,cup M804010 Outer M88048,cup M88010 Pinion bearings and races (cup)
PostPosted: Tue Aug 07, 2012 2:48 pm
Great .. That is helpful - There were toom many options on rock auto and I didnt want to order the wrong stuff.
Got the inner Bearing and race and the outer bearing, race and seal.
PostPosted: Tue Aug 07, 2012 3:24 pm
That is for sure! I looked about 10 times before I ordered my carrier bearings to make sure I got the right ones. :lol:
Rick
PostPosted: Wed Aug 08, 2012 9:16 am
Yep that's fo sho' Rick.
That's why I asked before ordering.
