| g360 transmission on a slant 6 https://slantsix.org/forum/viewtopic.php?t=49523 |
| Author: | enrique lopez [ Fri Aug 10, 2012 8:13 am ] |
| Post subject: | g360 transmission on a slant 6 |
hello everyone. has any one tried or does any one know if a g360 5 speed transmission can be used on a slant 6? the A833od is just to weak for me and I would like to have a fith gear. I have a np435 in it now, (great transmission), but only goes 1:1.0 tried the a883od, hated it. so I have the bell for both of these trannies. thank you. |
| Author: | olafla [ Sat Aug 11, 2012 10:25 am ] |
Stock 4-speed overdrive transmission ratios (from 1979 manual): 1: 3.09 2: 1.67 3: 1.00 4: 0.71 R: 3.00 Getrag G360 5 Speed Gear Ratios 1: 5.53 2: 3.02 3: 1.60 4: 1.00 5: 0.77 R: 5.03 Unless you have a need for crawling really slow rearward, or forward in first gear, an ordinary overdrive 4-speed transmission should do the job. (even if you hate it!) Also take a look at the comments here: http://www.quad4x4.com/Dodge_Getrag_G360_Parts.html Olaf |
