How do you keep your race car tires from going flat..?
https://slantsix.org/forum/viewtopic.php?t=49630
Page 1 of 2
Author:  Rob Simmons [ Tue Aug 21, 2012 1:08 pm ]
Post subject:  How do you keep your race car tires from going flat..?
The Challenger has big slicks and screws in the rims. The tires go flat within just a couple days. One of the fronts does too.. :(
Is there a method / secret to getting race slicks to hold air?
Author:  75customdart [ Tue Aug 21, 2012 1:09 pm ]
Run tubes
Author:  Greg Ondayko [ Tue Aug 21, 2012 1:39 pm ]
You Probably have a leaky valve stem and or a leaky rim seal on the front..
Tubes in the rear.
Air em up& spray a solution of dish soap and water to find the leaks..
Author:  Rug_Trucker [ Tue Aug 21, 2012 3:39 pm ]
Nitrogen+Tire Slime? :lol:
Author:  Reed [ Tue Aug 21, 2012 3:58 pm ]
What would a fix be for a leaky rim seal?
Author:  DusterIdiot [ Tue Aug 21, 2012 6:06 pm ]
Post subject:  Umm...
How old are they? If they date coded for 10+ years time to replace and save your life.... :wink:
-D.idiot
Author:  ceej [ Tue Aug 21, 2012 6:07 pm ]
My secret to success: Take them off, dump the air, and store them in a cool dark place.
Race slicks: Throw them away when they are two years old. Get fed up, and boil steet tires. adjust dial accordingly!
:lol:
CJ
Author:  Rug_Trucker [ Tue Aug 21, 2012 6:08 pm ]
Spray on undercoating.
Author:  slantzilla [ Tue Aug 21, 2012 7:10 pm ]
Put the car on stands and let the tires go flat.
Author:  emsvitil [ Tue Aug 21, 2012 7:12 pm ]
Add Air.......
:lol:
Author:  madmax/6 [ Tue Aug 21, 2012 8:00 pm ]
The real correct answer is coat the inside of the tires with dawn dish soap several times before mounting,Serious,,google it.Works for my car.I dont run tubes and dont need to add air.Guzzi Mark
Author:  Greg Ondayko [ Wed Aug 22, 2012 5:58 am ]
Yes or the real stuff tire stores use for slow leakers:
BEAD SEALER
Soap works well too, espically for getting the tire to pop over the rim but repeated applications of soap on the rims tend to cause corrosion.. so I use a slimy armor all type stuff for that purpose as it's oil based.
Author:  Reed [ Wed Aug 22, 2012 7:35 am ]
Thanks Greg. I have two rims that leak badly around the entire bead surface.
Author:  Slanted Opinion [ Wed Aug 22, 2012 10:08 am ]
Add Air.......
:lol:
There's one Joker in every thread... :lol:
Author:  75customdart [ Wed Aug 22, 2012 10:30 am ]
Reed. Tires leaking around the bead has become a real problem in the last few years. Being. in the tire business i see this everyday. The best way to fix this is to use a flap wheel on a grinder and remove all the peeling chrome and corrosion from the bead flange. Prime and paint. Apply bead sealer we use the Myers brand. MT tire using wd40 and set to desired pressure. Normally this will last the life of the tire if the wheels are kept clean in the winter.
Page 1 of 2 All times are UTC-07:00
