| my friends cuda https://slantsix.org/forum/viewtopic.php?t=4965 |
| Author: | Brents65cuda [ Sat Feb 08, 2003 11:53 am ] |
| Post subject: | my friends cuda |
my friend alos has a 65 and is putting a v8 into it he was wondering if there were any headers that would fit on a 82 318 that would work with a power steering pump, without having to cut stuff up and if he had to cuts stuff up then what type of headers should he get. |
| Author: | slantzilla [ Sat Feb 08, 2003 1:41 pm ] |
Choices are pretty limited for the early A. Spitfire comes to mind, but it's a crapshoot as to when you'll get them. However, he does make the only set that don't require cutting out the fenderwells. (I think) Post over on Moparts about Harold/Spitfire, someone will give you his phone number. |
| Author: | kesteb [ Mon Feb 10, 2003 1:10 pm ] |
If you don't mind paying the coin, the old '68-'69 340 HIPO exhaust manifolds will fit with a little massaging where the coupling collar strikes the right side manifold. The sb magnum manifolds might fit, but you would have to try them on for fit. |
