It is currently Sat May 30, 2026 10:51 pm
 Post subject: bench seat interchange
PostPosted: Fri Sep 28, 2012 6:33 am
Hi all,
I feel like I'm currently sitting on a toilet bowl when driving around in my '66 Dart wagon. It has a bench up front, and I would like to replace it.
Do I have to find another Dart to take it off of, or can I look for other older A-bodies as donors?
Thanks, Mike
1966 Dart Wagon
1967 Volvo 122s
1989 Ford F350 4x4
PostPosted: Fri Sep 28, 2012 7:46 am
an A-body is an A-body for example i pit a '72 dart swinger seat in my dads 383 duster it fit like a glove id just keep the body style/ year in the same area like 64-66 and you should be fine
trying to keep it low key here in my Valiant200
PostPosted: Fri Sep 28, 2012 10:14 am
Your seat's springs and foam are pshot. You can have the seat rebuilt; see here. Another old bench seat will likely be in similar condition to your existing old bench seat. You may want to consider updating the seating comfort and safety of the car by installing Chrysler Sebring seats which have inbuilt 3-point seat belts. They can be reupholstered to match your car's interior, if you wish. There's a good how-to on this swap (which requires not just the seats but also their electric control module) here.
It is not correct that "an A-body is an A-body". The pre-'67 A-bodies are narrower than the '67-up A-bodies, for example. You can adapt a lot of different seats not originally from a '63-'66 A-body, but a direct toss-in swap they are not.
PostPosted: Fri Sep 28, 2012 2:20 pm
I have a green bench seat you can have for free if you want to pick it up. It has high back rests and is out of a 73 Valiant. The vinyl is surprisingly nice for being as old as it is.
PostPosted: Sat Sep 29, 2012 5:24 am
sorry dan thats what i was trying to say but it came out sounding like all a-bodies where the same
