It is currently Mon Oct 12, 2026 3:34 am
 Post subject: JP Billet Timing Set
PostPosted: Sat Sep 08, 2012 3:20 pm
Has anyone used the Billet timing set from JP. It looks like a very nice piece and has 9 key ways, for less money than the factory double roller set.
I am thinking about getting one. Thanks,
Rick
PostPosted: Sat Sep 08, 2012 5:26 pm
Car Model: 64 Valiant
That quality was actually what I was expecting when I got in on the Cloyes buy-in a while back. Had I know the Cloyes was going to be a cast gear instead of billet. like their other timing sets, I would have gotten the JP set instead.....still might.
PostPosted: Sat Sep 08, 2012 6:17 pm
I used one on my truck and its going back on the new engine. Craftsmanship was excellent and very sturdy, just the bottom gear was kind of tight. When I took it off my engine it had zero stretch after 10,000 miles.
I definitely recommend them.
82 D150-225/727
02 Dakota-3.9/5 speed
 Post subject: Yep
PostPosted: Sat Sep 08, 2012 6:29 pm
When I pulled mine off the last engine I had it on, it left some scratches on the crank snout because it was so tight. Otherwise, it was a good setup for the price.
PostPosted: Sat Sep 08, 2012 6:53 pm
Somebody ought to do a group buy I'd take one for my next build
http://youtu.be/2Y4i4UOLiSA
http://www.forabodiesonly.com/mopar/sho ... p?t=126611
PostPosted: Sat Sep 08, 2012 8:17 pm
Thats what I run on my engine,Guzzi Mark
 Post subject: Thanks!
PostPosted: Sun Sep 09, 2012 5:12 am
Ok Thanks, That's what I wanted to know!
Rick
PostPosted: Sun Sep 09, 2012 5:19 am
A group of 5 are on E-Bay right now for $89 with free shipping! :lol: :lol:
Now there are only 4!
Rick
PostPosted: Sun Sep 09, 2012 6:09 pm
Rick
Now there's 3
PostPosted: Sun Sep 09, 2012 7:09 pm
Now there's 3
two remaining..
PostPosted: Sun Sep 09, 2012 8:33 pm
Bottom Gears And Balancers being tight are nothing new... Just a bit of fine sandpaper or a light grit roll on a dremel can take car of that.
 Post subject: Actually...
PostPosted: Sun Sep 09, 2012 9:03 pm
The Cloyes crank gear comes off easily with a sprocket puller or a little heat... and went on easily with some judicious heating with a torch...The JP sprocket doesn't like to let go with the sprocket puller without 15 minutes and a torch...(doesn't make for easy timing changes using the added crank key ways...)
The scratches left over from the last pull didn't come out with some casual polishing using 400-500 grit emery cloth...I started with 150 grit worked back down to 500...That engine has a cloyes set on it, it went together without a struggle...
It's really tight, FYI.
PostPosted: Sun Sep 09, 2012 9:24 pm
More Dremel needed Before instalation..
I wonder what the Correct interfencerce fit is for these parts...
Time to measure some old factory timing gears removed from cranks and some old cranks to see..
Once we get that measurement we can then hone or hog out the Replacement parts before Heating and beating them on.
PostPosted: Sun Sep 09, 2012 9:34 pm
Greg, i've had to hone many of the billet Cloyes crank gears on Chevy's and Ford engines, they recommend .0015 of interference. I have also had to do the same thing with Fluidamperâ„¢ and other balancer crank hubs, so it isn't uncommon to have to do that.
