8 1/4 gear change
https://slantsix.org/forum/viewtopic.php?t=49773
Page 1 of 2
Author:  Reed [ Tue Sep 11, 2012 2:09 pm ]
Post subject:  8 1/4 gear change
Assuming the rest of the axle assembly is in good shape (axles, bearings, etc...), what parts will I need to swap an A-body 8 1/4 rear axle from a 2.2 gearset to a 3.2 gearset? I have a 3.2 ring, pinion, and carrier out of an early 70s Dodge van ready to go, but what else will I need/should I have on hand? Any special tools I will need to get the gears set up right? I have a magnetic base dial indicator, but will I need more?
Thanks.
Author:  hantayo13 [ Tue Sep 11, 2012 6:12 pm ]
a new crush sleeve ...an air impac to tear apart
Author:  Reed [ Tue Sep 11, 2012 7:51 pm ]
I'll order up a new crush sleeve, I got the air wrench covered.
Author:  Fopar [ Tue Sep 11, 2012 8:22 pm ]
How about an inch/pound torque wrench dial or beam type.
Richard
Author:  Reed [ Tue Sep 11, 2012 9:15 pm ]
Torque wrench- check!
Author:  Junior [ Wed Sep 12, 2012 5:47 pm ]
are there any write ups on this yet? i was wondering how to do it myself
Author:  Reed [ Wed Sep 12, 2012 8:46 pm ]
If anyone has a link to a how-to article on changing 8.25 gears, please share.
Author:  Greg Ondayko [ Thu Sep 13, 2012 9:42 am ]
You will also need a large& internal Hex tool to do the Lash adjustment..
I forget the size of the Hex - probably like 1.25" or something...
I made one by getting an old pair of transverse tortion bars off of an FJM body donor car, cutting the bends of of them and then welding the 2 cut ends togther.. it's the correct size hex for the job, and will be a longer than the axle tube.
I am not sure if you can get the spanner wrenches in there like you might use on an 8.75 Setup.
Author:  Reed [ Thu Sep 13, 2012 9:53 am ]
Uh oh. Thank's Greg. I will have to investigate that further once I get the axle up on my bench and can get a really good look at it.
Author:  CNC-Dude [ Thu Sep 13, 2012 9:58 am ]
Any pics of your tool you made Greg. Also pm sent.
Author:  Reed [ Thu Sep 13, 2012 10:40 am ]
I forgot I had previously found this writeup on a Jeep site:
JEEP link
Looks like Randy's Ring and Pinion sells the adjuster tool for $65.
Author:  hantayo13 [ Thu Sep 13, 2012 5:31 pm ]
a bent screwdriver works if caps not bolted tight,once set tighten caps and install keepers/screw
Author:  DusterIdiot [ Thu Sep 13, 2012 5:48 pm ]
Post subject:  Lol...
Old C-body torsion bar works good too...
:wink:
Author:  Junior [ Thu Sep 13, 2012 6:14 pm ]
so i read the write up and seems pretty good. what would be the difference between that and a rear with a sure grip?
Author:  Greg Ondayko [ Fri Sep 14, 2012 3:58 am ]
Post subject:  Re: Lol...
:wink:
YES you are right... I forgot...
' round these parts Old Junk c bodies / parts are getting scarce, but Plenty of F/J/M cars left rotting from 1989 still ' round here. :D
Page 1 of 2 All times are UTC-08:00
