carter carb 63 Dart
https://slantsix.org/forum/viewtopic.php?t=49804
Author:  JimD [ Fri Sep 14, 2012 6:10 pm ]
Post subject:  carter carb 63 Dart
does anyone know what the carter carb number is , I need a rebuild kit, also the best place to buy the kit, thanks Jim.
Author:  SlantSixDan [ Fri Sep 14, 2012 6:35 pm ]
For a quality gaskets-and-seals kit, I prefer the kits from www.daytonaparts.com because they contain a better design of inlet needle and seat. Specify a kit for a Carter BBS #3678s and you'll get the right kit. Unfortunately, like all gasket kits these days, it will not come with the necessary stamped-cardboard float gauge. You will be given a useless little strip of paper ruler and assumed to make do the best you can. :-(
If you are after a very complete overhaul kit (incl. jets, etc.) my go-to source is www.thecarburetorshop.com .
Carburetor operation and repair manuals and links to training movies and carb repair/modification threads are posted here for free download.
Author:  Doc [ Mon Sep 17, 2012 9:11 am ]
A "side-note" on carb rebuilding...
The carb's float adjustment has an operating "range" and I have found that running the float bowl fuel level, on the low side of the range, gives me the best over-all "driveability".
To be honest, I run the float (fuel) level under the stated range, on many carbs I rebuild, especially the Carter BBS... and get pretty good results.
Basically, get the float bowl's fuel level too low and you will feel fuel lean-out and starvation, during hard cornering and braking.
Set it on the high side and you get a rich condition from "sloshing" and easier "boil-over", causing harder hot re-starts.
Carberators are going to evaporate-off any fuel sitting in the float bowl, (given time & heat) so I try to keep as little fuel as possible, in the bowl.
Long story short, this is one of those adjustments were less tends to be "better".
My 2 cents...
