75k transmission making noise in 1st gear
https://slantsix.org/forum/viewtopic.php?t=49828
Author:  65Dodge100 [ Tue Sep 18, 2012 12:31 am ]
Post subject:  75k transmission making noise in 1st gear
I have a 64 truck with about 75k miles on it. It just started making a rattling noiise when in first gear - not pulling, not holding back, just coasting. Rattle, Rattle Rattle. Push the clutch and it stops, push the gas and it stops. Going down a hill where it's holding the truck back and it makes no noise.
Does the front bearing wear out at 70k on these transmissions?
Thanks,
Danny
Author:  65Dodge100 [ Fri Sep 28, 2012 4:25 pm ]
Bump
Author:  Dart270 [ Sat Sep 29, 2012 4:14 am ]
This may just be the main gears slapping back and forth as the engine and driveshaft swap load surfaces on the gears. AFAIK, my T5s have always made this noise. W/o hearing it, it's hard to say.
If it's loud, then you might be dealing with a main or input or countershaft bearing??
Is this a ball & trunion driveshaft on an 833 4spd trans? If so, I have 2 of them in my garage that I just acquired.
Author:  emsvitil [ Sat Sep 29, 2012 4:13 pm ]
Is 1st gear straight cut or helical?
I can see straight cut gears rattling....
