| 833 swaped in for a 833od https://slantsix.org/forum/viewtopic.php?t=49835 |
| Author: | giezy [ Tue Sep 18, 2012 1:14 pm ] |
| Post subject: | 833 swaped in for a 833od |
can the bearing retainer be swapped over from a od to a four speed and the non od 833 be used in its place? my trans locked in 2nd now and is flat worn out |
| Author: | Doc [ Tue Sep 18, 2012 1:39 pm ] |
Err... just add an adapter ring to make-up the size difference. DD
| Author: | DusterIdiot [ Tue Sep 18, 2012 6:08 pm ] |
| Post subject: | Yep, or... |
If you are lucky enough to find a 1975-1976 A-body or 1976-1980 F body with a 3 speed, the unit will have an input bearing retainer that will bolt to the 833 and fit the OD bell...pretty much a tough to find item, and Wildcat/Brewers want some $$$ for one if in stock. -D.Idiot |
| Author: | giezy [ Wed Sep 19, 2012 8:39 pm ] |
any one got one? |
| Author: | ESP47 [ Fri Sep 21, 2012 7:23 am ] |
Isn't the overdrive bearing retainer bigger than the regular 4 speed retainer? I put up an ad on FABO last year and was able to trade a guy mine for an OD retainer. Put up an ad over there and see what you can get. |
| Author: | DusterIdiot [ Fri Sep 21, 2012 7:02 pm ] |
| Post subject: | But... |
Quote: Isn't the overdrive bearing retainer bigger than the regular 4 speed retainer?
Yes but there are things that have to happen:1) The A-833OD uses a larger diameter bearing retainer...but the input bearing is the large 308 style bearing that you would find in the 440/6pak and hemi 18 spline boxes... 2) The standard A-833 and most 3 spds, use the smaller 307 input bearing so their retainer bolt pattern is much smaller... So the choices are: Sleeve like Doc has shown. 1975+ A-230 bearing retainer (small bearing bolt pattern with the 5.125" retainer diameter). -D.Idiot |
