2.2 Turbo Pistons
https://slantsix.org/forum/viewtopic.php?t=49853
Author:  earlymopar [ Thu Sep 20, 2012 11:41 am ]
Post subject:  2.2 Turbo Pistons
I read where using Dodge 2.2 Tubo pistons on 198 CI slant 6 rods can provide a nice set-up although the comment I read had no specifics or details. Are any of you running this and if so, how is it working for you and how are you using it (street only street / race, etc)? These pistons appear to be dished. With that in mind, what have you done with deck height / quench?
- EM
Author:  Doc [ Thu Sep 20, 2012 1:51 pm ]
I have built many of these engines ("long rod" 225's) and they are all working well.
The 18 cc dish "Turbo get you around 8 to 1 compression.
The "non-turbo" version, with the smaller dish or "valve groove" gets you in the 9 to 1 range.
A flat top piston at zero deck get you over 11 to 1 compression.
Author:  SlantSixDan [ Thu Sep 20, 2012 2:00 pm ]
Is there a materials or strength advantage to the turbo piston? Or is it just purely the dish size that differs?
Author:  Doc [ Thu Sep 20, 2012 2:39 pm ]
The piston material and over-all construction changes with each manufacturer.
With the Silvolite 2.2 pistons, there is the 1290H, 1291H & 1292, the first 2 ("H") are hypereutectic material and the 1292 is not. None of these have steel expansion control struts.
The factory 2.2 pistons have the steel struts but unknown material alloy.
The KB239 & 268 are also Hyper with no struts but use a special heat treatment for added hardness.
The Wiseco units are forged pistons and there were also forged TRW and Sealed Power units, that are now discontinued but some still "pop-up" now and again.
For a "budget" street build, the KB units are a good choice but more $$ then the Silvolite units. The Wiseco forged pistons are also a great value.
Shop around....
See http://www.kb-silvolite.com/kb_car/perf ... s&P_id=133
Author:  Turbo Toad [ Thu Sep 20, 2012 4:13 pm ]
One down side that I've come across with the 2.2 pistons is the price for a good set of rings, being that we need two sets of them.
I've been looking into using something different for my next build.
Author:  Doc [ Thu Sep 20, 2012 4:49 pm ]
There are a number of less expensive options.
See this thread:
http://www.slantsix.org/forum/viewtopic.php?t=25197
Author:  Turbo Toad [ Thu Sep 20, 2012 5:44 pm ]
Thanks doc I've already crossed reference some of them ring sets looks like you can use some of the Toyota 6 sets if i remember correctly you need 1.5 1.5 4,for my next build I got 2.5 turbo pistons and 198 rods
Author:  SLANTEDRAM [ Fri Sep 21, 2012 11:16 am ]
you will only need one set of rings if ordered for a late model 3.0 toyota v6 engine- 1990 toyota pickup will be the right stuff- this is what I used- these rings must be file fitted first though as the ring gap was very narrow out of the box
