spacer for /6 head
https://slantsix.org/forum/viewtopic.php?t=49877
Page 1 of 1
Author:  goldbike [ Sun Sep 23, 2012 9:00 am ]
Post subject:  spacer for /6 head
Hello, I am new here, this is a great forum! the top of my engine block has been decked .090" does anybody make a .090-.100" steel spacer? My head has been milled .090" also. WAY to much compression. Any advice welcome. James
Author:  Fopar [ Sun Sep 23, 2012 9:39 am ]
Would be easier to get another head.
Richard
Author:  DusterIdiot [ Sun Sep 23, 2012 9:53 am ]
Post subject:  Yep...
New head would do it.
WAY too much compression.
Can you define "way too much compression"?
What did you calc it out at?
Author:  goldbike [ Sun Sep 23, 2012 10:05 am ]
I am going to get another head. Thanks, James
Author:  Will [ Sun Sep 23, 2012 10:18 am ]
90 and 90 sounds like a good combo to me!!!
Will
Author:  wjajr [ Sun Sep 23, 2012 1:54 pm ]
What camshaft does this engine have, stock, or some big aftermarket stick? Until you compute engine’s dynamic compression using actual dimensions from your engine, you’re just guessing. If the cam has sufficient overlap, you may be able to run it on pump gas.
Author:  Joshie225 [ Mon Sep 24, 2012 9:24 am ]
Will
Sounds good to me too. Just need the right cam along with free breathing intake and exhaust systems. :D
Author:  Kidd [ Mon Sep 24, 2012 8:22 pm ]
Sounds close to me.....then again I like 12:1 !!
Author:  Aggressive Ted [ Tue Sep 25, 2012 7:16 am ]
Sounds perfect! In fact, I would prefer more!
Author:  Dart270 [ Tue Sep 25, 2012 8:38 am ]
I think you could buy a copper head gasket (SCE and one other manufacturer?) and sandwich it between two composite gaskets.
I have also doubled up felpros to get about 0.068" total thickness. I use spray copper gasket sealer in between the gaskets but not on either side. Held fine in my 10:1 68 Dart motor for a few years.
Author:  Romeo Furio [ Thu Sep 27, 2012 11:30 am ]
I always thought that the 3 100's were the best starting point.
Bore .100 over. Mill head .100.. Deck block .100
Felpro permatorque head gasket is around .040
Author:  Romeo Furio [ Thu Sep 27, 2012 11:35 am ]
Forgot to say try Cometic, Talked to them at the SEMA show. They said they can do Slant head gasket whatever bore and thickness you want.
Worth a call.
Author:  Mroldfart2u [ Thu Sep 27, 2012 1:54 pm ]
Guess a flash in the pan, no replies or question answering... Makes one go hmmmm. :roll:
Author:  Romeo Furio [ Thu Sep 27, 2012 3:31 pm ]
crap, I hate when they promise the world at shows and then give you "Did I say That??"
Author:  Charrlie_S [ Thu Sep 27, 2012 5:32 pm ]
Worth a call.
That's not what I was told at the PRI show 2 years in a row :roll: :roll: :roll:
Hussey Copper will do a slant gasket copper gasket, any bore, and thickness.
