| Nylon distributor pinion for slant six https://slantsix.org/forum/viewtopic.php?t=49885 |
| Author: | 1966DartConvertible [ Mon Sep 24, 2012 8:39 am ] |
| Post subject: | Nylon distributor pinion for slant six |
Took the distributor out today to correct some timing issues. Apparently the timing runs off if I rev it hard a few times from idle. Upon inspection I found that the nylon pinion on my Prestolite slant six dostributor has seen better days. Even though that might not be the culprit, I better change it. If I were to buy new, are they all standard sizse? Do they have a steel ones like those used in modern engines? Thanks Syed |
