It is currently Sun May 31, 2026 10:40 pm
PostPosted: Tue Sep 25, 2012 10:37 pm
Got my distributor fixed, now mapping the ignition timing vs. RPM vs. load using the handheld trigger.
I can retard/advance the ignition timing at every 500rpm increments (15 steps i.e. 0 - 7500rpm) vs. load (throttle). Here is a picture or two :
and here ive also fitted the 3-3/8" Sun Pro Tacho on the column (can't fit on top, no clearance)
Syed
Malaysia
Cars: 1966 Dodge Dart 270 Convertible,
1990 Alfa 164 Twin Spark
1980 BMW 735i 5-speed
http://www.weddingcar4u.blogspot.com/
PostPosted: Tue Sep 25, 2012 10:49 pm
500 RPM steps are rather large for spark mapping. I also doubt you will get your slant to rev to 7500 RPM unless it is not stock. You have the right idea though, just get it down to 100 or 50 RPM steps.
PostPosted: Tue Sep 25, 2012 10:55 pm
I forget to say that you can map it up to 500rpm increment. I am doing 300rpm increments (0-4500rpm) which I think is reasonable, for a start.
Syed
PostPosted: Wed Sep 26, 2012 8:23 am
Does the system use linear interpolation between RPM steps? I'm hoping so as it would be a handicap to stair-step from one value to another at the 300 RPM thresholds. Also, are the step sizes fixed across the speed range?
PostPosted: Thu Sep 27, 2012 5:40 am
Interesting...
Good luck!
I have no idea what I am talking about.
PostPosted: Thu Sep 27, 2012 10:04 am
Syed I too had a clearance issue when mounting the same model tachometer to steering column at 2 0’clock. What I discovered is if the gage is mounted about ½ to ¾ inch from column it just fits. To accomplish this I crushed a short length of rubber hose left over from PCV valve re-plumb job which shimmed out the base of gage from column and held the whole shoot’en match on with a radiator hose clamp painted black.
Users browsing this forum: Amazon [Bot] and 1 guest
