It is currently Sat May 23, 2026 2:29 pm
PostPosted: Wed Sep 26, 2012 9:49 pm
Is it OK to install the pushrod on the master cyl and use the rod to do the bench-bleeding?
I would like to limit the work I have to do under the dashboard because of spinal trouble.
63 Signet / 10 inch front drums / weber 2bbl / HEI / 2.76 rear end
PostPosted: Wed Sep 26, 2012 9:57 pm
I don't see why not...
