Fail Safe Thermostat
https://slantsix.org/forum/viewtopic.php?t=49960
Page 1 of 1
Author:  64DartGT [ Tue Oct 02, 2012 8:26 am ]
Post subject:  Fail Safe Thermostat
Any thoughts on the Murray Fail Safe Thermostats.The 180 degree Stat.......?
Author:  SlantSixDan [ Tue Oct 02, 2012 8:27 am ]
Thermostats seldom fail. It's more important to get a good quality thermostat that does the best possible job of regulating minimum engine temperature than to worry about something that will probably not happen. Use a Stant SuperStat 45358.
Author:  64DartGT [ Tue Oct 02, 2012 8:36 am ]
Thanks Dan........I'll do that. My statis fairly new. It is the one you recommend, however after running it a while I noticed it quit going past a certain temp and dropping back down. Now it heats up to 180 and then over a period of time it gets warmer not overheating but definitely warmer. Is this a problem?
Author:  ESP47 [ Tue Oct 02, 2012 9:28 am ]
Warmer is better for power and economy as long as you aren't overheating. If you're cruising down the road doing 50mph on a cool day and your car is running as hot as you'd want to see it, then you're probably going to want to take a look at it. If you're running as hot as possible there, you're definitely going to overheat if you're sitting still in traffic in 95* weather.
Author:  64DartGT [ Tue Oct 02, 2012 1:30 pm ]
Thanks for the response ESP47 I guess I'm worrying too much ............
