BBS Carb Inlet Repair
https://slantsix.org/forum/viewtopic.php?t=49983
Page 1 of 1
Author:  Street Mechanic [ Fri Oct 05, 2012 4:50 pm ]
Post subject:  BBS Carb Inlet Repair
The threads in one of my BBS carbs are stripped by the brass inlet assembly.
At one time, parts stores had a replacement, which had a slightly larger diameter and would self-tap into the body.
Anyone know where to get one?
Author:  SlantSixDan [ Fri Oct 05, 2012 5:18 pm ]
The repair fitting you have in mind was never available for the BBS -- it was available for the Rochester Thermoquad. Time to find another carburetor body to build up.
Author:  Street Mechanic [ Fri Oct 05, 2012 7:08 pm ]
Thanks, Dan.
I did buy a Autoline rebuilt from Rock Auto. Figured I could rebuild it if necessary. (Knowing the bad reputation of store rebuilts.)
The problem there is that they use the same stock number for several years. First one I got was too early--no PCV connection (and I already had one of those).
Called Rock and they emailed a free return label to me.
Replacement was a 1964--Just what I needed. Surprise, it ran fine right from the start.
Both were quite clean with many new external parts.
Author:  SlantSixDan [ Fri Oct 05, 2012 7:10 pm ]
Thanks, Dan.
Oog. :-( Out of the frying pan and into the fire. Hope it works out okeh for you.
