It is currently Fri Jun 12, 2026 1:38 pm
 Post subject: BBS Carb Inlet Repair
PostPosted: Fri Oct 05, 2012 4:50 pm
The threads in one of my BBS carbs are stripped by the brass inlet assembly.
At one time, parts stores had a replacement, which had a slightly larger diameter and would self-tap into the body.
Anyone know where to get one?
Street Mechanic
1964 Valiant Signet Conv.
1965 Valiant Signet 2 Dr. sedan
PostPosted: Fri Oct 05, 2012 5:18 pm
The repair fitting you have in mind was never available for the BBS -- it was available for the Rochester Thermoquad. Time to find another carburetor body to build up.
PostPosted: Fri Oct 05, 2012 7:08 pm
Thanks, Dan.
I did buy a Autoline rebuilt from Rock Auto. Figured I could rebuild it if necessary. (Knowing the bad reputation of store rebuilts.)
The problem there is that they use the same stock number for several years. First one I got was too early--no PCV connection (and I already had one of those).
Called Rock and they emailed a free return label to me.
Replacement was a 1964--Just what I needed. Surprise, it ran fine right from the start.
Both were quite clean with many new external parts.
Street Mechanic
PostPosted: Fri Oct 05, 2012 7:10 pm
Thanks, Dan.
Oog. :-( Out of the frying pan and into the fire. Hope it works out okeh for you.
Users browsing this forum: Google [Bot], MazdaRX8/6 and 6 guests
