| crankshaft damper/pulley https://slantsix.org/forum/viewtopic.php?t=50008 |
| Author: | grr8_65 [ Mon Oct 08, 2012 4:03 am ] |
| Post subject: | crankshaft damper/pulley |
Adding power steering and A/C to my 65 Cuda. P/S pump located in the stock position, driver side low. A/C hopefully low on the passenger side. P/S pump and water pump to be driven by a single "v" belt, A/C and ALT to be driven by double "v" belts. Is a 3 groove "v" belt crank pulley/damper available? If I were to go with a 6 rib serpentine belt for the A?C, Alt, and bolt the drive pulley to the center of my stock 1 groove "v" belt crank pulley, would that interfere with the dampening function. I beleive so. Thanks for any comments and suggestions. Tom |
| Author: | slantzilla [ Mon Oct 08, 2012 6:02 am ] |
Yes, there are sheaves that bolt on the front and back sides of the stock damper. Yes, you will have to remove the damper to install the back one. PM Charlie_S, he does a neat A/C conversion and sells brackets for the Sanden compressor I believe. |
| Author: | grr8_65 [ Tue Oct 09, 2012 3:56 am ] |
Thanks for the info. I'll PM Charlie and see what we can come up with. I appreciate all the support that is in this forum. Tom |
