do i need a sealant when installing water pump?
https://slantsix.org/forum/viewtopic.php?t=50013
Page 1 of 1
Author:  67 Dodge Coronet 440 [ Mon Oct 08, 2012 2:38 pm ]
Post subject:  do i need a sealant when installing water pump?
hi Bear R.-here.just wandering if i need a gasket sealant for my water pump?its a chrysler water pump .it has a gasket under a metal plate that does not come off do to the blade.any ideas here.or,do i just bolt it on?thanks everyone God Bless you all,Barry.
Author:  Eric W [ Mon Oct 08, 2012 5:53 pm ]
I usually use the grey water pump and thermostat sealer from Permatex. Just smear some (lightly) on the gasket that mates to the block.
Author:  kielbasa [ Mon Oct 08, 2012 6:41 pm ]
It uses 2 gaskets, the one between pump and plate will come off, its a little tricky to fish it around. I personally used only sealer between block and gasket (block had some pitting)
