| Super Six Carb linkaage https://slantsix.org/forum/viewtopic.php?t=50018 |
| Author: | Normst [ Mon Oct 08, 2012 9:46 pm ] |
| Post subject: | Super Six Carb linkaage |
I've got a supersix manifold, carb and air cleaner, but can't find out what carb linkage will work. It is going on a 64 Dart 225 Any help appreciated. Norm |
| Author: | Doc [ Tue Oct 09, 2012 10:18 am ] |
http://www.slantsix.org/articles/supersix/article.htm |
| Author: | SlantSixDan [ Tue Oct 09, 2012 2:38 pm ] |
Your '64 Dart has a rod-type throttle linkage and accelerator pedal. You'll either have to retrofit a cable-type pedal and accelerator cable, or forget the Super Six intake manifold and modify a 1bbl intake to mount the 2bbl carb parallel rather than factory perpendicular and continue to use your existing linkage and pedal. See the parallel 2bbl setup article. Photo documentation of a very well done such conversion is here. |
