| Valve Spring Seats https://slantsix.org/forum/viewtopic.php?t=50088 |
| Author: | the_engineers [ Mon Oct 15, 2012 8:10 am ] |
| Post subject: | Valve Spring Seats |
I'm looking at running a different set of valves, but the new valve is .060" shorter than stock. Any issues machining the spring seats .060" to accomodate the change in overall length? |
| Author: | Dart270 [ Mon Oct 15, 2012 8:59 am ] |
I have wondered this same thing, but have not gotten confident answers from head experts. 0.060" may be OK, but you might want to experiment with a junk head first. You can always use Ford or Chev SB V8 valves, which are about 0.100" longer... Lou |
| Author: | the_engineers [ Mon Oct 15, 2012 9:48 am ] |
I wonder if a recessed retainer would cure any potential problems... |
| Author: | CNC-Dude [ Mon Oct 15, 2012 10:28 am ] |
Is your valvetrain going to be adjustable or non-adjustable. The tip height could also be .060" shorter as well and cause issues if your using a non-adjustable rocker arm. |
| Author: | the_engineers [ Mon Oct 15, 2012 5:42 pm ] |
Adjustable |
