It is currently Sat Oct 24, 2026 5:38 pm
PostPosted: Wed Oct 24, 2012 11:08 am
Did some searching and the consensus was to use a new head gasket on a motor that has been run. How about a motor that was rebuilt (in 1990) and has never been run nor had any fluids through it? Getting ready to pull the stock head on this particular motor, pull the cam for one suitable for my application and replace the head with one that has been mildly ported, O/S valves, milled, etc. I do have a NOS gasket set with the thin steel head gasket if it matters.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Wed Oct 24, 2012 11:41 am
Once crushed its used.
PostPosted: Wed Oct 24, 2012 12:08 pm
I will be the contrarian and say that I have successfully re-used cylinder head gaskets numerous times. As long as the sealing surfaces are clean and the gasket surface is not damaged, I have had good luck getting used cylinder head gaskets to reseal on STOCK (no forced induction) motors.
Best practice is to ALWAYS use new gaskets, but sometimes that just isn't possible for various reasons.
PostPosted: Wed Oct 24, 2012 1:17 pm
Unless you are well and truly stuck in an emergency situation (engine MUST get put back together right now, new gasket CANNOT be had) then reusing a crushed gasket is a foolish gamble.
PostPosted: Wed Oct 24, 2012 1:46 pm
Car Model: 1964 Valiant V200
I've done it several times, and it worked fine. However if someone else asked me for advice I'd tell them not to.
PostPosted: Wed Oct 24, 2012 3:28 pm
LOL it is easier to spend some one elses money, But that being said I concur. I HAVE done it several times with no ill effects but as a practice, no I dont LIKE to and would RATHER not, but sometimes....... ya do what ya hafta...
MRO....
PostPosted: Wed Oct 24, 2012 3:49 pm
Has anyone reused their steel shim head gasket??
Rick
PostPosted: Wed Oct 24, 2012 4:05 pm
The situation is definitely not an emergency and I do have a new steel shim gasket. I pulled the head this afternoon and it's one of those FelPro composition-type gaskets. No sealer was used on it and looks brand new. However, I'm gonna take no chances and will use the new steel gasket I have.
By the way Dan, this motor is getting the Lynx triple SU I bought from you quite awhile ago. I used your recommended SU guru (Rhys Kent - Island Automation) who rebuilt a set of HIF6s for me.
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot] and 15 guests
