Do i need a kickdown rod
https://slantsix.org/forum/viewtopic.php?t=50154
Page 1 of 1
Author:  wormswiggleinn [ Mon Oct 22, 2012 11:52 am ]
Post subject:  Do i need a kickdown rod
Do i need a kickdown rod on my 73 dodge dart
Author:  SlantSixDan [ Mon Oct 22, 2012 11:56 am ]
Yes. If you don't have one the transmission will quickly be damaged.
Author:  Reed [ Mon Oct 22, 2012 12:23 pm ]
If you have an automatic transmission the answer is yes.
If you have a manual transmission, the answer is no.
Author:  wormswiggleinn [ Mon Oct 22, 2012 1:39 pm ]
Post subject:  Thanks
Thankyou i just got the two barrel on and running. But i don't have all the linkages where would i find pictures to make one
Author:  Doc [ Mon Oct 22, 2012 2:52 pm ]
http://www.slantsix.org/articles/supersix/article.htm
Author:  wjajr [ Tue Oct 23, 2012 6:13 am ]
There is always the aftermarket “kick-downâ€￾ throttle position cable solution. [url=http://www.summitracing.com/parts/LOK-KDP-2904U/]Lokar[/url], [url=http://www.bouchillonperformance.com/BPEtkdc.asp]Bouchillon[/url] made of mostly factory like components, similar to Bouchllon’s [url=http://chucker54.stores.yahoo.net/kiccabkit1.html]Mancini[/url], and the junk yard cable & bits from rear drive late 80's early 90's dodge truck.
