mechanical oil pressure gauge.
https://slantsix.org/forum/viewtopic.php?t=50197
Author:  phogroian [ Sat Oct 27, 2012 1:54 pm ]
Post subject:  mechanical oil pressure gauge.
Since my oil pressure warning light came on and the pressure bypass section of the oil pump looks good, I was going to install a pressure gauge to find out what the true pressure is.
I see that most have a 3/8" fitting but it looks as if the pressure sending unit has a large 5/8", fine thread fitting. Should I find adapters or is there a pressure gauge that will fit?
Does anyone sell replacement oil pressure sending units for the warning light?
Author:  Mike_64_Valiant [ Sun Oct 28, 2012 8:18 pm ]
Any auto parts store should have the sending unit. As far as the mechanical gauge goes, some kits have a couple diffrent addapter and if yours does not then a good hardware store with brass fittings will do the trick.
But before you change the sending unit check and make sure the wire is in good shape. I found mine became brittle from the heat and was grounding out making my light come on.
