Magnecor leads
https://slantsix.org/forum/viewtopic.php?t=50216
Author:  SlantSteve [ Tue Oct 30, 2012 2:33 am ]
Post subject:  Magnecor leads
Hi guys, I'm just completing the hei conversion at the moment and was about to order a set of Magnecor leads ..... What type has been used ? The 7 mm cable or are the KV85 cables the choice? The engine is basically a rebuilt mild street only engine. Thanks
Author:  Greg Ondayko [ Tue Oct 30, 2012 7:22 am ]
I used those wires on my race car project.. Been raing for 3 years now.. Bulletproof.. I believe I used the Larger ones but for a mild street Build the smaller dia. would be good as well.
Author:  wjajr [ Tue Oct 30, 2012 11:22 am ]
I installed the 8mm wires this spring, no more electrifying moments during timing adjustments… Nice thick high quality insulation & boots.
Author:  SlantSteve [ Thu Nov 01, 2012 5:30 am ]
Thanks for the replies guys,I ended up going with the 7 mm leads, they were the only black wires Magnecor had in stock here in Australia and was told they are fine for my needs. Thanks! Steve
