It is currently Thu Nov 12, 2026 10:33 pm
 Post subject: Electric fuel pump?
PostPosted: Fri Nov 23, 2012 7:05 pm
Hi gyes I have a 1969 custom four door dart . It's a 225 slant six and I want to get the most racing performance out of it possible . Well my questions are can somebody tell me what's the best electric fuel pump and ignition I can get like any recommendations on either one. Getting electric fuel pump witch one for best performance and what electric ignition system is best. Thanks everyone I would REALY appreciate the answer.:)
PostPosted: Fri Nov 23, 2012 8:30 pm
You can run in the 14s before you need an electric fuel pump. If your mechanical pump is good then run it until you need more fuel delivery.
HEI is a very cost effective and powerful ignition system. http://slantsix.org/forum/viewtopic.php?t=15779
The things that really restrict the 225 are not terribly cheap or inexpensive to rectify. You have to improve the intake, exhaust, cylinder head and compression ratio to really make a big difference. These things have all been discussed at length and are here for you to read.
PostPosted: Sat Nov 24, 2012 7:23 am
I run in the 12's with the stock mechanical Fuel Pump installed on ruster.
The ole mechanical should be fine in most situations.
