| 1962 Valiant Signet - rear quarter window rubber https://slantsix.org/forum/viewtopic.php?t=50402 |
| Author: | crickhollow [ Sat Nov 24, 2012 2:58 am ] |
| Post subject: | 1962 Valiant Signet - rear quarter window rubber |
I am restoring a 62 Signet GT 2 door coupe. The rear quarter window rubber is unusable as it is badly perished/damaged. I am after a solution for a replacement window rubber. Any ideas? NOTE: The rear quarter vent window and window rubber on the 2 door coupe and 2 door sedan is a different size to the 4 door sedans - they are bigger. Thanks, Peter |
| Author: | John Brayton [ Fri Nov 30, 2012 7:39 pm ] |
| Post subject: | Re: 1962 Valiant Signet - rear quarter window rubber |
Quote: I am restoring a 62 Signet GT 2 door coupe. The rear quarter window rubber is unusable as it is badly perished/damaged.
Hi Peter,I am after a solution for a replacement window rubber. Any ideas? NOTE: The rear quarter vent window and window rubber on the 2 door coupe and 2 door sedan is a different size to the 4 door sedans - they are bigger. Thanks, Peter I'm working on the same car and was able to get the rubbers from Pentastar... www.pentastarparts.com,au I wasn't able to get the rubbers to accept the original stainless but felt it was better to have good weather stripping than the trim. Contact them and make sure you get what you want. Good luck with your Toad! Regards, John Brayton |
