It is currently Sun Oct 25, 2026 7:42 am
 Post subject: carb for 85 ram
PostPosted: Wed Feb 19, 2003 5:51 pm
what kind of carb can i use on my 85 ram. i have a 4bbl intake, headers, and getting my new cam from from clifford. i also would like what size of cam should i use to get top performance. with the carb ive been told 390cfm is the max you want to use on a slant six. ive also been told i can go higher.
 Post subject: carbs
PostPosted: Wed Feb 19, 2003 6:07 pm
The edelbrock 500 and the holley 390 are commonly used on the /6
PostPosted: Wed Feb 19, 2003 8:42 pm
Anything is possible...
Both the 390 Holley and 500 Edel are good carbs for a street/strip motor or a daily driver. What do you mean by "top performance" and what will you use your truck for?
PostPosted: Wed Feb 19, 2003 9:26 pm
I think I would get the edelbrock instead. It just seems better built, no plastic parts and no gaskets below fuel level... Esp a plus since my holley 390 just started leaking between the screw heads and fuel bowls
PostPosted: Mon Feb 24, 2003 9:08 am
i say with a mild build, run a 500 cfm edel.
86 dodge ram w-150
4.10's 4 speed manual
4 inch lift 36's wrapped around weld 15x10 typoons , bored .030, shaved .060, ported, headers, 4-barrel 500 cfm carb, clifford intake& headers, isky racing springs and cam, MP electronic igin,
PostPosted: Mon Feb 24, 2003 5:01 pm
I run the Edelbrock 500 on my '83 Ram. The engine is a stock 225 with Clifford intake and headers and a MP electronic ignition. I have an auto trans and used Lokar throttle cable, kickdown cable and bracket kits. This setup runs great and has given me no problems.
Ron
Users browsing this forum: Bing [Bot] and 28 guests
