Smashed electrod
https://slantsix.org/forum/viewtopic.php?t=50455
Author:  lowbudget [ Thu Nov 29, 2012 7:20 am ]
Post subject:  Smashed electrod
After making a 60 mile trip my 77 Aspen started running rough coming down Main Street. When I got home I pulled the plugs and found the electrode on the #2 plug bent over to the side and 1/4 of the insulator missing. So what happened?????? Both bolts on choke plate are still there.
A quick comp check showed 85 PSI compared to 105 on #3
If I have time I'm going to pull the valve cover off when I get home tonight.
Thanks In advance Mike[/img]
Author:  Slanted Opinion [ Thu Nov 29, 2012 10:14 am ]
Well, we know that your plug to piston clearance didn't suddenly change, so perhaps the insulator cracked, fell down into the cylinder and got mashed into the electrode.
I think I would install another plug, crank the engine over with the coil disconnected, and then remove the plug to see if it is undamaged.
- Mac
Author:  lowbudget [ Fri Nov 30, 2012 2:22 pm ]
I cranked it over with out plug before I stuck my compression gauge in it. I put a new plug in it and cranked it over, then started it and ran it a couple minutes. The gap was the same as when installed.
I guess I will pull the head come spring and look at everything just for piece of mind. I would do it now but I'm headed back to work for 28 days.
Thanks Mike
Author:  Rug_Trucker [ Fri Nov 30, 2012 10:00 pm ]
Autolite? Champion? What brand?
Author:  lowbudget [ Sat Dec 01, 2012 7:46 am ]
NGK's that have been in car for 10,000 miles at least.
Author:  emsvitil [ Sat Dec 01, 2012 4:11 pm ]
Some detonation/pinging may have cracked the porcelain.
Then it broke off, bounced around and bent the electrode.
Author:  Supercharged SL6 [ Sat Dec 01, 2012 4:18 pm ]
More than likely the detonation took the top of the piston land off
