| regulator epoxy goo https://slantsix.org/forum/viewtopic.php?t=50456 |
| Author: | 75valiant [ Thu Nov 29, 2012 8:15 am ] |
| Post subject: | regulator epoxy goo |
when i bought my valiant, there was some type of voltage regulator mounted on the left side fender that had fried. i bought a new one and it runs and charges fine. my question is, what can i use to remove the epoxy goo that dribbled all down my inner fender? that stuff is ON there, and it's nasty looking. i've got a clean car, only 63,000 one owner miles. |
| Author: | robertob [ Thu Nov 29, 2012 8:24 am ] |
I can't think of anything that won't harm the paint. Acetone or MEK will remove it but might damage the paint. Maybe try cleaning solvent/Naptha/Mineral Spirits? |
| Author: | Mroldfart2u [ Thu Nov 29, 2012 9:25 am ] |
Try WD40... and a plastic dish scrubber. (NOT a 3M pad type) |
| Author: | 75valiant [ Fri Apr 26, 2013 6:31 am ] |
decided just for fun to hit it with the old power washer. i was initially impressed, but it seemed that the water just kind of "beat it up." later, i was leaning under the hood when much to my surprise my hand was glued to the inner fender. seems i have brought it back to life. i noticed that when i first posted this thread, the charging system was working fine. now it's not. the only thing i can think of is maybe i got something wet. in any case, i've still got work left to do. |
| Author: | 75valiant [ Sat Apr 27, 2013 2:36 pm ] |
wonderful chinese- made borg warner voltage regulator was stuck open. got a new regulator and the rebuilt alternator charges like crazy. |
| Author: | Aggressive Ted [ Sat Apr 27, 2013 4:17 pm ] |
Did you ever get the goo off your hand? and the car? I use lacquer thinner let it dry well, then polish it with some wax. The product "Goof Off" works well too... |
| Author: | 75valiant [ Mon Apr 29, 2013 12:05 pm ] |
hey, i'll try that! thanks! |
