| Drag Radial storage? https://slantsix.org/forum/viewtopic.php?t=50491 |
| Author: | Rick Covalt [ Tue Dec 04, 2012 4:17 pm ] |
| Post subject: | Drag Radial storage? |
I know folks try and take their slicks and store them in "warmer" temps over the winter. Is there any reason to do the same with Drag radials? I have another set of wheels I can swap onto my car for the winter, but didn't know if it mattered? Thanks, Rick |
| Author: | slantzilla [ Tue Dec 04, 2012 6:28 pm ] |
If nothing else, I would jack the car up and put stands under the frame so the weight is off the springs and tires. Then at least they won't flat spot. |
| Author: | Greg Ondayko [ Tue Dec 04, 2012 7:06 pm ] |
No Reason no not heed these suggestions if your car is just sitting.. I Remove the Racing Tires - air them down to 5 PSI and Stack them in a corner of the basement (which is Heated) I dotn cover them 'cause My basement is dark unless I am working in there.. and I try to keep them away from electric Motors. More Infos Below.. http://www.hoosiertire.com/safetywarning/index.htm http://www.mickeythompsontires.com/tech.php?bulletin=s5 Greg |
| Author: | Rick Covalt [ Wed Dec 05, 2012 3:18 am ] |
Thanks! I'll swap them off and store them in my basement. Thanks, Rick |
