It is currently Sun Nov 15, 2026 11:52 am
PostPosted: Fri Dec 21, 2012 1:36 pm
does anyone know the diameter of the small bolt pattern axle flanges?
1966 Plymouth Valiant, 225, 3 on the tree, 8 1/4 3.21 sure grip, hyperpac, holley 650dp, holset h1c
PostPosted: Fri Dec 21, 2012 6:18 pm
I don't know if they are the same, or not. 7 1/4 rear or 8 3/4 rear?
Edit: Went out to the shop and measured.
They are both the same. just a "tick" under 5.300 inches. They vary a little bit, between 4 axles
PostPosted: Fri Dec 21, 2012 6:59 pm
thank you
