| Valve noise- Solved! https://slantsix.org/forum/viewtopic.php?t=50557 |
| Author: | ValiantBoyWonder [ Thu Dec 13, 2012 2:02 pm ] |
| Post subject: | Valve noise- Solved! |
Driving down highway, car has been running great, suddenly the engine rpms increased, and then went back to normal. Car idles well and throttle response is great. but there is a loud clanking noise. I readjusted the valves and checked rocker arm play. Clanking happens only in drive. I recently changed head gasket and manifold gasket. What caused high rpms on highway and resulting noise? |
| Author: | Valleyant [ Thu Dec 13, 2012 4:41 pm ] |
Possibly a ballooned torque convertor? |
| Author: | ValiantBoyWonder [ Thu Dec 13, 2012 11:43 pm ] |
What happen?: after replacing head gasket and manifold gasket, set kick-down to full open with throttle fully open. Set valve lash to .12 and 24 as an initial setting to get the car going and warmed up. I was going to adjust the valves at work. It's a 20 minute drive. Halfway to work, i was doing 70mph at about 2700 rpm, the engine surged (as if the tranny dropped into 2nd - it's a 904 automatic) and then everything returned to normal. At the stop light off of the freeway, i began to hear a "clack clack clack". I parked it at work and pulled out the feeler gauges thinking that the valves were too loose. set them .10 and .20 but clack clack persisted. clack is still there with valve cover off. I observed the rockers opening and closing the valves, everything appeared to look normal. i decided to let the engine rest and troubleshoot later. here's what i've done/checked so far: torque converter bolts - tight checked exhaust - no rattles trans fluid okay oil pressure 50 - 60psi engine temp 190 - 200f spark to all cylinders pumped 89 octane thinking the engine was pinging checked spark plugs - tan colored, nothing strange kick down cable hasn't slipped motor mounts and trans mount okay timing at 10btdc symptoms: -clacking happens in drive, between 1500 and 2200 rpm (if i shift down to 2nd, the clacking becomes quieter) -shut engine off and let it cruise down the street - no clacking -the sound is coming from what i believe to be #1 cylinder (or front of engine) thanks guys. |
| Author: | Doc [ Fri Dec 14, 2012 10:16 am ] |
Remove & cut your oil filter open... look for "bad stuff". No metal in the filter & no change in oil pressure then it's likely a piston or valve problem. DD |
| Author: | ValiantBoyWonder [ Fri Dec 14, 2012 2:21 pm ] |
Tore into at work (i love being a mechanic) it appears the #1 intake pushrod is bent (sticking valve?) Getting parts today, will post results later. Thank you! |
| Author: | Mroldfart2u [ Sat Dec 15, 2012 6:52 am ] |
Quote: Tore into at work (i love being a mechanic) it appears the #1 intake pushrod is bent (sticking valve?)
Possibly stuck for a split micro second, or enough clearance to let push rod move to a "bind" position are a couple of "guesses"..Getting parts today, will post results later. Thank you! Others may chime in... |
| Author: | ValiantBoyWonder [ Tue Jan 08, 2013 3:33 pm ] |
the clanking became louder, i marked it as "the tell tale slant". i took the following steps: i let it run with the valve cover off. i noticed that the #1 exhaust push rod was not spinning (new push rod installed). i removed the lifter and the face was somewhat flat, but still had a bit up a roundness to it. i replaced the lifter anyway. i thought maybe the lifter had stuck, so i changed the oil and added a quart of trans fluid to loosen it up a bit maybe. engine ran better but the clacking persisted. as per doc's instructions, i cut open my filter and found no "bad stuff". over the weeks i became increasingly worried that my daily driver would one day clank itself to death. i figured if one of the valves had burnt, a compression test would show me the results. compression for all cylinders was between 125psi and 130psi. even when wet, the compression stayed around the same. so this led me to believe the valves were okay. as well as the rings. that night, my dad and i probed the engine with a long copper pipe. no weird bottom end noises, the sound was coming from the front of the engine. he's a plumber, so he had this uv goop that we spread on the runners looking for cracks, it bubbled near the front exhaust manifold and rear runners. the manifold is warped! based on this picture i took the first time it came off, it looks like it didn't seal at all before! ![]() not sealing correctly, causing that tiny little clanking whistle. we let the engine run for awhile and then loosened the manifold bolts while hot, shifted the manifold around a bit and the sound was no longer there. so... i'm buying one of those new Chinese exhaust manifolds to replace this one, because from what i can see, that manifold is extremely warped. when i replaced the manifold gaskets, i did not check to see if the runners were a flush fit. i knew i should of checked it. dammit. when tightening the manifold, i start in the middle and work my way out? (same as torquing the head correct?) i was thinking of lightly putting the manifold on there, doing the nuts finger tight, and as the engine warms up and everything settles, torquing it to spec. suggestions? also, should i tighten the 3 intake to exhaust bolts prior to torquing the manifold to head nuts? i will be buying the remflex gaskets as preventative measure. is it true that if you run the car long enough with an exhaust leak the possibility for burning valves increases? i love this forum. |
| Author: | Valleyant [ Tue Jan 08, 2013 3:59 pm ] |
I bet you feel better now knowing what the problem was/is. If you go into the article section of the forum and look for manifold installation, it will answer all your questions. Thats what I used when I super 6 and it has worked out great! |
| Author: | ValiantBoyWonder [ Tue Jan 08, 2013 5:43 pm ] |
the engine problems don't bother me as much as the "not knowing" the not knowing gnaws away at me. |
| Author: | 63Valiant [ Tue Jan 08, 2013 6:39 pm ] |
Here's the write up on installing the exhaust manifolds, it's lengthy, but worth the read, a lot of good info there: Slant Six Exhaust Manifold Installation |
