| Lean burn dizzy part number https://slantsix.org/forum/viewtopic.php?t=50561 |
| Author: | Turbo Toad [ Thu Dec 13, 2012 5:14 pm ] |
| Post subject: | Lean burn dizzy part number |
Maybe some can help I need a part number for a lean burn replacement locked dizzy with no vacuum port I was a looking on rock auto but it doesn't say whether or not its a lean burn unit #303693 is this the correct number? Thanks Aaron |
| Author: | DusterIdiot [ Thu Dec 13, 2012 5:57 pm ] |
| Post subject: | Why not...? |
I can sell you one at the same price and I've gone through it and toleranced and lubed it (the cardone will not be lubed and you are on a crap shoot if the even set the gear right and checked the bushing clearance....(you also will get a single pickup instead of the random possiblilty of getting a dual pickup version as well...) I will be doing recurve work on Saturday if you want me to clean one up, check it and put a new pick up in it. I can drop it in the mail the same day... Send me a PM. -D.Idiot |
| Author: | Turbo Toad [ Thu Dec 13, 2012 7:16 pm ] |
Pm sent |
