It is currently Thu May 21, 2026 7:02 pm
PostPosted: Thu Dec 13, 2012 5:14 pm
Maybe some can help I need a part number for a lean burn replacement locked dizzy with no vacuum port I was a looking on rock auto but it doesn't say whether or not its a lean burn unit
#303693 is this the correct number?
Thanks Aaron
http://youtu.be/2Y4i4UOLiSA
http://www.forabodiesonly.com/mopar/sho ... p?t=126611
 Post subject: Why not...?
PostPosted: Thu Dec 13, 2012 5:57 pm
I can sell you one at the same price and I've gone through it and toleranced and lubed it (the cardone will not be lubed and you are
on a crap shoot if the even set the gear right and checked the bushing
clearance....(you also will get a single pickup instead of the random
possiblilty of getting a dual pickup version as well...)
I will be doing recurve work on Saturday if you want me to clean one up, check it and put a new pick up in it. I can drop it in the mail the same day...
Send me a PM.
PostPosted: Thu Dec 13, 2012 7:16 pm
Pm sent
