| Does my engine still require a valve lash adjustment? https://slantsix.org/forum/viewtopic.php?t=50575 |
| Author: | 86ramslant6 [ Sat Dec 15, 2012 6:28 pm ] |
| Post subject: | Does my engine still require a valve lash adjustment? |
My truck is an 86 and it still has the original engine, I'm not sure if the previous owner would have ever done this adjustment but I want to make sure it is taken care of if in fact it needs it. Thank you. |
| Author: | Reed [ Sat Dec 15, 2012 6:33 pm ] |
If it is an 86 truck with the original motor it will have hydraulic lifters and will not need a valve lash adjustment. |
| Author: | 86ramslant6 [ Sat Dec 15, 2012 7:55 pm ] |
awesome thank you! I was a little concerned with learning the right way to do this procedure |
