| New Coil https://slantsix.org/forum/viewtopic.php?t=50581 |
| Author: | Danarchy [ Sun Dec 16, 2012 4:21 pm ] |
| Post subject: | New Coil |
Anyone have a preference on ignition coils? Stock 1964 225 /6 (1.5 ohm?) Closest to home: NAPA-Part Number: MPE IC12SB http://www.napaonline.com/Catalog/Catal ... 0359797040 |
| Author: | mpgmike [ Mon Dec 31, 2012 3:27 pm ] |
For an easy bolt-in, I like the Blue Streak brand (Standard Ignition product line). If you want nice and cheap, I like the '90s E-coil used on the 2.5 engines. This requires splicing in the appropriate connector and different coil wire connector. An alternative is the '80s oil coil from the turbo cars & V-8s. They have a different tower connector, but will take you from about 17 KV potential to around 50 KVs. Mike |
| Author: | Danarchy [ Mon Dec 31, 2012 4:18 pm ] |
I ended up with the cheapo NAPA coil from china. It got my car running, but will probably be replaced in the near future, and go up on a shelf as a spare. |
