It is currently Fri Nov 27, 2026 7:17 am
PostPosted: Sun Dec 16, 2012 6:57 pm
Very bad news with the Toad.... bought a complete and rebuilt 73 /6 from one of our /6 guys. I've had the engine for over two years waiting to be installed. The installation is complete but when we tried to rotate the crank it was frozen... somehow water got into three cylinders and rusted solid. We measured the depth of rust and it is beyond the milling specs. What a let down! Now, moving forward..... I have a 62 block and wonder if I have it milled, can I use the crank and pistons from the 73? Did the 225 block change from 62 to 73? Thanks for your input!
John Brayton
707 953-9947
1962 Plymouth Valiant
PostPosted: Sun Dec 16, 2012 8:34 pm
6 Pack Dart
should interchange just use the 73 crankshaft (difference in torque converter front end) early have small diameter pilot end.
Richard
PostPosted: Mon Dec 17, 2012 8:02 am
Thanks Richard,
The newer block had a total rebuild with a more aggressive cam and we're hoping to use as much of it as possible.
Regards,
John Brayton
PostPosted: Mon Dec 17, 2012 8:28 am
6 Pack Dart
I just noticed you have a 62, are you using the automatic from a 60-66 or one from 67 up.
Richard
PostPosted: Mon Dec 17, 2012 8:34 am
How many cylinders got rusty & pitted, one?
If it's just one cylinder, have a sleeve installed and rebuild that engine.
PostPosted: Mon Dec 17, 2012 11:58 am
Hi Doc, The three with their valves open are rusted. Do you think it makes cost sense to sleeve all three?
John
PostPosted: Mon Dec 17, 2012 12:06 pm
Not for 3 cylinders... (Sleeving costs about $75.00 per "hole")
Check cost to bore a different block and go that way... if about the same price.
PostPosted: Mon Dec 17, 2012 5:58 pm
We didn't use the automatic.... went with a A833 od instead.
JB
