| Oil control - scrapers, windage tray or both? https://slantsix.org/forum/viewtopic.php?t=50610 |
| Author: | robertob [ Thu Dec 20, 2012 7:47 am ] |
| Post subject: | Oil control - scrapers, windage tray or both? |
For a low-rpm motor (redline 5000-5500 rpm max), what is the best method of oil control? I'm more concerned with starvation while cornering than I am with power gains although any added power will be a bonus. I am planning to braze some baffles in the stock pan, I might even section and fabricate some side kick-outs. But my real question is concerning the cost/benefit of scrapers and windage trays. Mike Jeffries can sell me a windage tray for $189 with all the hardware. The guy in Florida can sell me some slick scrapers for $89 The cheapskate in me thinks that $89 beats out $189 any day, but if the windage tray will give more benefit, it might be worth saving a little more. |
| Author: | slantzilla [ Thu Dec 20, 2012 8:28 am ] |
Mike also sells scraper kits, they are just a little more labor intensive than Johnson's. Johnson's will need fitting, just not as much as Mike's. Mike's is a ton cheaper though. I have a Jeffrey tray and Johnson scraper in my motor. For a street only motor I would not bother with a tray. It just doesn't do that much in the RPM range a street motor runs in. |
| Author: | robertob [ Thu Dec 20, 2012 9:16 am ] |
Thanks. I like the Johnson scrapers because they have trap doors in them, do the Jeffries ones? I will have to call Mike and ask about his. I just asked him about Windage. |
| Author: | Greg Ondayko [ Thu Dec 20, 2012 9:32 am ] |
Baffles, trap doors and kickouts are best for road course purposes.. I have a baffle made in my ruster Pan along with a tray and scraper. It's for a drag only car.. but you will get the idea.. Info links below. http://www.slantsix.org/forum/viewtopic ... c&start=45 http://www.slantsix.org/forum/viewtopic ... c&start=60 http://www.slantsix.org/forum/viewtopic ... c&start=75 http://www.slantsix.org/forum/viewtopic ... c&start=90 Hope this is helpful. Greg |
| Author: | madmax/6 [ Sun Dec 23, 2012 8:38 pm ] |
I have 1 scraper,a windage tray,deeper pan and baffles.think they work. |
| Author: | robertob [ Thu Jan 03, 2013 9:44 am ] |
Thanks guys, lots to think about. I might just stick with the scrapers based on the cost/benefit ratio, as well as modify the pan. |
