| small bolt pattern axle flange https://slantsix.org/forum/viewtopic.php?t=50616 |
| Author: | Junior [ Fri Dec 21, 2012 1:36 pm ] |
| Post subject: | small bolt pattern axle flange |
does anyone know the diameter of the small bolt pattern axle flanges? |
| Author: | Charrlie_S [ Fri Dec 21, 2012 6:18 pm ] |
| Post subject: | Re: small bolt pattern axle flange |
Quote: does anyone know the diameter of the small bolt pattern axle flanges?
I don't know if they are the same, or not. 7 1/4 rear or 8 3/4 rear?Edit: Went out to the shop and measured. They are both the same. just a "tick" under 5.300 inches. They vary a little bit, between 4 axles |
| Author: | Junior [ Fri Dec 21, 2012 6:59 pm ] |
thank you |
