| relays https://slantsix.org/forum/viewtopic.php?t=50628 |
| Author: | Slanty [ Sun Dec 23, 2012 11:16 am ] |
| Post subject: | relays |
First i would like to say i have always adored slant six....my last car was a straight six rambler but now im proud to own a 78 volare wagon.I was thinking of adding relays to the hei i put in..blower motor...and headlights as well as beefing up the headlight wiring.How does this sound? |
| Author: | Mroldfart2u [ Sun Dec 23, 2012 12:14 pm ] |
You sure are not going to hurt anything, and maybe even help out the 30+ year old wiring and switches.. |
| Author: | Reed [ Sun Dec 23, 2012 12:31 pm ] |
| Post subject: | Re: relays |
Quote: I was thinking of adding relays to the hei i put in..blower motor...and headlights as well as beefing up the headlight wiring.How does this sound?
Sounds like very good and often recommended upgrades!
| Author: | coconuteater64 [ Sun Dec 23, 2012 1:04 pm ] |
I did the relay thing when I added HEI and also spliced in a "kill switch" to deenergize said relay. Might come in handy while working underhood and need the engine shut down right now should an emergency arise. |
| Author: | olafla [ Sun Dec 23, 2012 7:38 pm ] |
Relays, and also upgraded wires - if necessary - is a very good idea, check here for the voltage loss in the wiring harness in my Aspen. Gm Hei Module Conversion Troubles As long as you're under the hood, do yourself a favour, and double check all your ground connections and fusible links. Happy Holidays. Olaf |
| Author: | Slanty [ Mon Dec 24, 2012 12:48 pm ] |
Ok so i added a nice bosch 30amp relay to the heater much better perfornance..then put one on my hei..then put a 60 amp fusible link behind the alt...how does this sound? |
| Author: | 64ragtop [ Wed Dec 26, 2012 1:14 pm ] |
All sounds good, Slanty, and welcome to the forum. ATB BC |
