It is currently Thu Nov 26, 2026 2:00 pm
 Post subject: Idle speed increasing
PostPosted: Sat Dec 29, 2012 4:37 pm
Hey guys,
My idle speed has been steadily increasing. About 2 months ago my warm idle in drive was 550-600 and 700-800 in park. Over these past two months these have been gradually increasing to the point where I'm idling at 850-900 in drive and 1200-1300 in park. I've tried to back off my idle speed screw but it's not even making contact anymore (318 BBD). Anyone have any ideas of what is causing my idle to increase?
I'm getting ready to adjust my valves (for the first time in the 3 years I've owned the car) and will be setting my mixture via SSDan's post here (first time doing that myself too). I'm also wanting to re-do my timing at that time (Another first). As far as I know, these are the only things that affect idle speed. Am I on the right track for fixing this problem? Anything else I should look into? I want to get this squared away before I do the HEI retrofit.
Has anyone or does anyone set their timing with a vacuum gauge? (like this says)
Thanks for the help,
Aspen76
76 Dodge Aspen
225 Super Six w/ Dutra True Dual Exhaust
http://i1245.photobucket.com/albums/gg5 ... AG0095.jpg
http://www.youtube.com/user/BZuko1?feature=guide
PostPosted: Sun Dec 30, 2012 2:13 am
Yeah, advanced timing can raise the idle or air going around the throttle plate somehow (like a vacuum leak, worn throttle shafts, carb gaskets etc.)
Maybe the valve are too tight also, compounding the problem. Either way you're gonna have to get the basics right first before yo do anything concerning updating the ignition etc. I would set the valve lash correctly as the first order of business. Then confirm that the timing is correct AT idle (making sure that the timing mark is correct would be a god idea also). Than try setting the idle with the vac gauge and if necessary, locate any vacuum leaks and fix them. Good luck .
1979 W150 Shortbox
225, NP435, 9 1/4, Dana 44
The Good Life.
PostPosted: Sun Dec 30, 2012 5:46 am
Chances are good you have several small problems combining causing idle speed to increase.
Where idle speed has been creeping up over time, suspect a worsening vacuum leak. It could be anywhere in all the tubing and vacuum devices that entangles a ’76 engine, any of the dashpots and if equipped with AC its controls, at carburetor flange to manifold, manifold to head, PCV plumbing, and if you have power brakes that is another location for a leak to occur. Some of these vacuum circuits can be capped off at the carburetor, or manifold for brakes one at a time as a test.
Once you get engine to idle back down to factory setting, then you can set the lash. Setting lash on an engine running much faster than 500 rpm can be a messy tedious task.
If you can’t locate a vacuum leak, suspect a carburetor problem where throttle is hanging up when trying to fully close due to a groove worn into side of barrel, a sloppy fitting throttle shaft in body, or some problem with linkage hanging up such as high idle cam, throttle cable, or even kick down adjustment. Clean outside of carburetor, and all moving linkage, and make sure it all is able to freely articulate.
Timing can be checked & adjusted easily, engine idle speed can also be changed with timing adjustment; retard lowers it, and advance brings it up. Inspect distributor governor and springs, if weights are sticking and unable to fully retract at idle, idle speed will stay elevated. Make sure governor weights are free to move; check springs for tightness or ability to fully retract weights, clean and Lube mechanical advance if needed, don’t forget to give small felt in center of distributor’s shaft under rotter button a few drops of light oil.
PostPosted: Mon Dec 31, 2012 7:58 pm
Hey guys,
I think I found one of the small problems. I was sitting in a parking lot today with my idle reaching up to 1450 in park. I slide my foot under the pedal and pulled up slightly and it immediately dropped to 1100. The movement upward on the pedal wasn't perceivable to my foot but it made a difference to the car. Once I tapped the gas, it returned to 1450. If the throttle linkage is getting caught up on something how do I go about cleaning it and lubricating it. I ask because I've read that using oil lubricants (like WD-40) will cause more issues down the road as it gathers dirt. I'll get my fiance to lift up on the pedal while I'm under the hood tomorrow to see if I can see where it's getting hung up.
I'll be heading to Advanced Auto tomorrow (or the next day) for a new battery for my fiance's car so I'll pick up a bunch of new hoses and replace them all (should have done it when I bought the car 3 years ago). I suspect the power brakes connection to my manifold the most for a vacuum leak because it is the most brittle and it's a big hose clamped on a very small nipple. I'll test it tomorrow by squeezing the ends (even though I plan to replace it).
I'm really hoping the issue isn't any deeper than vacuum leaks and a stick linkage. The sooner I get this figured out, the better, as I'll have all the components for the HEI swap :D.
Thanks for all the help,
Aspen76
76 Dodge Aspen
PostPosted: Mon Dec 31, 2012 8:53 pm
im having the same problem with mine and in my trucks manual it says the heat valve(i think) is stuck or sticking i just spray it with some sort of penetrating oil and when i turn it back on it will be back at normal idle again. the object im talking about is on the exhaust manifold below where it hooks onto the intake there is a rod or two sticking through on both sides and i just spray those i think its the one with the wrap around spring. it lasts for a bit on my truck and then it starts idling high again and i will just spray it with wd40 or penetrating oil AFTER it cools off and 9/10 times its normal idle. the 1/10 times i just spray it again. not really a permanent fix but hey works for me :lol:
BTW the exhaust manifold on mine is really rusty and so i think that may have something to do with my problem.
65 dodge military d200 225 /6
66 dodge d100 225 /6
 Post subject: Fixed
PostPosted: Sun Jan 06, 2013 7:02 am
I fixed it, got under the hood and had my fiance rev it a few time. A nut was loose on my throttle linkage, the one that hold it to the throttle on the carb. I tightened it and my idle dropped immediately.
Thanks for all the help!
Aspen76
76 Dodge Aspen
Users browsing this forum: Google [Bot] and 15 guests
