A833OD question
https://slantsix.org/forum/viewtopic.php?t=50676
Page 1 of 1
Author:  YardDart63 [ Mon Dec 31, 2012 12:20 am ]
Post subject:  A833OD question
Hello guys. First let me say I feel honored to be part of the Slant Six Forum.
I hope to someday swap an O/D A833 into my 63 Dart. I know I would need the pedal assemblies and a new driveshaft, but what else would I run into attempting this swap? Also, what clutch would y'all recommend for a bone-stock street car? Thanks in advance.
Author:  Rug_Trucker [ Mon Dec 31, 2012 7:11 am ]
727 slip yoke. I am not sure but there may be a set of pedals on Moparts.com for rhe early A for sale.
You will also need a 4 speed hump.
Author:  DusterIdiot [ Mon Dec 31, 2012 7:25 am ]
Post subject:  Yep...
Clutch pedal set and hump is needed, and the driveline is correct. Beyond that you will need the clutch linkage as well and a flywheel that matches your motor (pre-67 flywheel if you have a pre-67 engine).
For a bone stock engine that you won't be drag racing the stock 9 1/4"
clutch should be just fine and can be had inexpensively if you shop around
(Zoom has served me well in that capacity in the past). The bellhousing from the donor vehicle will also be needed.
You will need the slip yoke for the tranny, but be warned that there is a change in yoke around the late 70's....my 1975 iron case units, all truck units, and my '76 OD's use the A-727 "large yoke"...I have an aluminum unit from 1978 that uses the smaller A-904 yoke. Hopefully you can get the yoke and drive shaft from the donor vehicle so it's matched.
Good Hunting.
Author:  Rug_Trucker [ Mon Dec 31, 2012 12:01 pm ]
Post subject:  Re: Yep...
[quote="DusterIdiot" The bellhousing from the donor vehicle will also be needed.
-D.Idiot[/quote]
Makes me think my shorty 833OD is an F body unit. It had truck shifter linkage on it. :shock: I pulled it out of a '74 Duster roller I bought. It took the 727 SL.
BTW I have several 833 bells with shift forks for sale, one is a hydraulic unit.
Author:  Supercharged SL6 [ Mon Dec 31, 2012 5:13 pm ]
If your getting the trans out of a pickup ( that are readly available) the tailshaft, mainshaft is going to be longer than an A ,F body trans, also shifter postion is differernt. I bought a complete setup flywheel, bellhousing, trans from a pickup, measured it up and it looked like it would have fit if you installed rear trans mount backwards, shortened driveshaft, with 727 yoke and made up a custom shifter and linkage. I opted to switch out the main and tailshaft with A ,F body parts so I could use stock driveshaft, shifter. A guy in Syracuse N Y who worked at the New Process factory, has lots of parts and swapped my long tail and main shaft for the short ones, the long tailshafts are the same ones that are used in Cuda's and Challengers and are worth $$$, check Brewer Performance and see what the going price is. If any one wants his number I can try to find it, if you can find a A ,F body trans your good to go with maybe just switching yoke on driveshaft
Author:  DusterIdiot [ Mon Dec 31, 2012 7:02 pm ]
Post subject:  You sure about that?
Truck trans install is in our articles section with 4 speeds.
He's got a 1963 Ball and Trunnion drive shaft...can't just swap yokes...
Author:  YardDart63 [ Wed Jan 02, 2013 7:38 pm ]
I sure thank y'all. I don't really have the money to put into it at the moment, but I figured it would be better to learn all I can ahead of time.
Author:  DonPal [ Tue Jan 08, 2013 2:35 pm ]
The list is a little longer for the swap into an early a body automatic.....
The flywheel must fit your crankshaft......must be something like pre 67 to avoid machining.
The bellhousing must be an OD bellhousing to avoid machining.
You may need a floor hump.....I got an aftermarket 68 and used it in my 65.
You'll probably find that most available mechanical clutch linkage has a broken torque tube......best to go hydraulic and avoid the failures typical of fatique worn linkage..I learned this the hard way.
Check your rearend ratio.....hopefully it's somewhere between 2.94 & 3.21....As a guage my slant with 2.94 rear & trans in OD has 2000 rpm at 70 mph & pulls well up the hills at that speed but shows weakness at 55 mph on the same hill.
