It is currently Thu Nov 26, 2026 4:50 pm
 Post subject: Holley 1barrel numbers
PostPosted: Wed Jan 02, 2013 1:47 pm
Can someone help me with a parts number book? I need to identify which model of the 1920 Holley used on a 1976 feather duster, with manual a833od.
Also, the vacuum amplifier, as these were not only one year parts but differ between auto and manual.
Dart lite info also works.
I just need the numbers to verify so that the feather duster's clone by Doug and EGR with wider throat which start at startup work in harmony, as I am to understand it, the carburetor's vacuum circuits open switches at 'programmed values' aka as heat,opens signal vacuum valves.
Please help.
Thanks
Slant six should have stayed in production.
