Air Cleaner lid gasket
https://slantsix.org/forum/viewtopic.php?t=50683
Page 1 of 1
Author:  73dust225 [ Mon Dec 31, 2012 5:28 pm ]
Post subject:  Air Cleaner lid gasket
I need the gasket that goes in the groove of the top of the air cleaner. Can anyone tell me what I can use in place of it or can I get a replacement one. This would be for the 1973 1bbl air cleaner.
thanks for any help.
Author:  theomahamoparguy [ Tue Jan 01, 2013 12:06 am ]
#1 find another lid with gasket. #2 search through the salvage yard; there probably are some similar lids with an old gasket that you could use on yours. measure and trim to suit. might have to get a bit creative.
Don't know who would have a new one.
Author:  Valleyant [ Tue Jan 01, 2013 12:02 pm ]
Post subject:  Re: Air Cleaner lid gasket
Hi,
try www.detroitmuscletechnologies.com
I have gotten a few heater box rebuild kits and he mentioned wanting to reproduce the air cleaner lid gaskets a while back....good luck!
Author:  73dust225 [ Tue Jan 01, 2013 12:45 pm ]
Hi,
Thanks I'll check it out.
Author:  Valleyant [ Tue Jan 01, 2013 2:45 pm ]
Another tip that I find may work ok. I have found these lids in the salvage yards and someone had put in vacuum hose, don't know the size but they used the whole thing and stuffed it into the groove around the whole perimeter...seems to be an alternative.
Author:  jollyrajr [ Tue Jan 01, 2013 5:58 pm ]
Did this with my '67 Beatercuda when I couldn't find a replacement gasket for the rotted out one--
They sell that stuff that's basically a rubberized gasket in a can.. I forget the name of it now, but parts stores have it.. It looks a lot like Easy Spray Cheese you can get at the supermarket, but in black.. eww. Anyway, I dug out the crusty remains of the old gasket and fulled in the spot with the rubber insta-gasket.. I smoothed it with a finger (next time I'll use a guitar pic or something rounded..), let it dry, and it worked like a charm..
Alternately-- I really like the rubber hose idea mentioned by someone else.. Would be an entirely reversible deal.. (Unless you greased up the inside lip of the aircleaner before you used the rubber gasket-in-a-can..)..
Just some thoughts..
Raj
Author:  Eric W [ Wed Jan 02, 2013 4:54 am ]
Sounds odd, but you can also use a oil filter gasket for the air cleaner base gasket. At least it works on a Holley 1920.
Author:  73dust225 [ Wed Jan 02, 2013 9:28 am ]
Thanks for the suggestions. I'll have to look into them, even may be the rubber whiz in a can (sounded better in my head lol).
