EDIS install
https://slantsix.org/forum/viewtopic.php?t=50684
Author:  jacmifish [ Mon Dec 31, 2012 6:03 pm ]
Post subject:  EDIS install
Hi guys. The purpose of this was to let you guys see my current project on my duster. Right now I'm installing the EDIS system with megajolt. In the future I plan to use Megasquirt.
The following pictures are the install of the trigger wheel.
Author:  jacmifish [ Wed Jan 02, 2013 3:32 pm ]
Post subject:  VR sensor bracket
This bracket will hold the VR sensor. Used an L bracket and bent, cut and welded it with sleeves for bolts. Mocked this all on a spare motor.
Please excuse my welding
Just applied some coating because I'll be back at school.
Author:  jacmifish [ Mon Feb 25, 2013 10:30 am ]
Post subject:  Up and running
Alright so I had a chance to come back down from school and wire things up. Put everything in their mocked up locations and it cranked right up =) . I didn't run it for long because of no radiator attached. Sorry no pictures I forgot. Next time I'll try running a proper advance map and take some pictures.
Author:  Greg Ondayko [ Tue Feb 26, 2013 8:07 am ]
Nice work. I think this belongs in in the EFI section - Mainly because Mega Jolt is an offshoot of the Megasquirt EFI controller.
I have wanted to do this upgrade for quite a while.. I have all the parts just not the time yet. :-(
Author:  jacmifish [ Tue Feb 26, 2013 11:06 am ]
Whoops :P when I get everything correct I will make another post there.
Thanks!
