| not sure what to do https://slantsix.org/forum/viewtopic.php?t=50685 |
| Author: | 66militaryd200 [ Mon Dec 31, 2012 9:49 pm ] |
| Post subject: | not sure what to do |
well the subject says it all. the motor on one of my trucks has a cracked block i think because there is a streak of jb weld about the same size as a football outline right under the manifolds. not really sure if there is any cracks under it or what. but im with the group of people with the mind set that if it aint broke dont fix it as in i dont really want to replace the motor till i have too OR i have read some stuff about locknstitch awhile back and you use it to make a mostly permanent repair on the block their website has more info on it. it seems like a really good block repair option. but im just all confused on what to do for said motor problem what do yal think |
| Author: | ceej [ Mon Dec 31, 2012 10:08 pm ] |
If I had that engine, and it was running, and all was fine with it right now, I'd leave it alone. Don't set a wrench to it until you must, or when you replace it. Such an engine will likely start sucking you into project creep until you have some actual money in it. That you should avoid. Spend your money on something you plan to keep. I wouldn't even attempt a manifold swap. You may start backing Heli-Coils out of the head, and then find yourself pulling the head, and once there... See what I mean? Get your plan together for your new engine, start with something that will be serviceable, then experiment with stitching the old block up. If it doesn't work, your out very little. Just what I'd do... 2¢ CJ |
| Author: | Doc [ Wed Jan 02, 2013 9:35 am ] |
Vote #2 on finding a different engine and spending your time & $$ on getting that engine ready to swap-into the truck. Any time / $$ spent on a cracked engine block, is a waste... DD |
| Author: | 66militaryd200 [ Wed Jan 02, 2013 5:31 pm ] |
thanks for the tthoughts on this! also im gonna put like 410s or higher in the front and rear because i will be either mudding alot or pulling out logs for money |
| Author: | Slanted Opinion [ Fri Jan 04, 2013 4:02 am ] |
It's a free country... you are welcome to put in whatever engine you like. But if it is torque you're after (and it sounds like that's the goal for log pulling and mudding) then the slant has it in spades. - Mac |
